Dzien dobry .
Jak w tytule ;) Czy ktos juz probowal takiego rozwązania ,zna je i moglby przyblizyc o co chodzi ? Podobno  gra lepiej niz "Malina"
https://www.micromedia.ch/?portfolio=aes67-dante-aoip-stereo-interfaces
https://www.hifi12a.de/epages/61785497.sf/en_GB/?ObjectPath=/Shops/61785497/Categories/AoIP/Micromedia
"Dante (Digital Audio Network Through Ethernet) is a combination of software, hardware, and network protocols that deliver uncompressed, multi-channel, low-latency digital audio over a standard Ethernet network using Layer 3 IP packets
In a Dante-enabled device, the hardware takes digital audio and ‘packetizes’ it. Basically, it segments the audio and wraps it in IP (Internet Protocol) packets suitable for transmission across an Ethernet network. The packets contain timing information and source and destination network addresses, allowing them to be efficiently routed through the network to the correct destination.
When a device receives Dante audio packets, it reconstructs them back into a continuous digital audio stream, which is then played out, recorded, or digitally processed, depending on that device’s role in the audio system.
Hardware Dante devices support exceptionally low latency (on the order of microseconds, rather than milliseconds), and common low-latency applications (for example, real-time monitoring during recording) are easily supported.
Clock synchronization is critical to the success of any audio network. For packetized audio to synchronize perfectly across the network, all devices need to share identical timing information. This is achieved by the presence of a single master clock, which provides synchronization information for all devices. Dante ensures that the most stable and accurate clock automatically becomes the master clock. All other devices automatically lock to that device, eliminating any network timing issues."
Edytowano przez THX1138
