luckyliu Napisano 5 sierpnia 2020 Napisano 5 sierpnia 2020 Set the current time according to the steps under "Basic settings". 2. Press the set button: the words "1" and "NO" should appear on the LCD display during the period. 3. Adjust the minutes for timing: Press the minute Milfra Smart Light Switch button to set the minutes to 45. 4. Adjust the timing: Press the hour button to set the hour to 6. 5. Set the day of the week: Press and hold the week button until the week mode MO, TU, WE, TH, FR is displayed on the LCD screen. Then press the setting button on the LCD. The words "1" and "OFF" are displayed on the LCD for the period. Above you will find an introduction to setting the smart socket in the "Timing function" setting. The function of the Smart Plug is relatively Milfra EU Smart Light Switch extensive. Follow the steps in the manual to set the function. Three or three types of smart connectors Smart Socket is a very powerful socket. Depending on the type of smart socket, it can be divided into three categories: the dosing plug, the control plug and the remote control plug. Let's take a look at the three types of smart sockets Odpisz, cytując
