Ra1stlin Napisano 28 października 2024 Udostępnij Napisano 28 października 2024 Audio Analogue Maestro CD / DAC - cena 4100zl Srebrno - czarny, stan bardzo dobry. Wyjścia – zbalansowane elektryczne AES/EBU (XLR), niezbalansowane elektryczne RCA. Dodatkowo wyjście i wejście cyfrowe SPDIF (podłączysz dodatkowe źródło cyfrowe - komp, streamer). Mozliwosc wypuszczenia syglalu do zewnatrznego przetwornika DSP 44/96khz ( i powrot w petli) Pilot w komplecie - nosi juz mocniejsze slady uzytkowania . A CD player that can also be used as a digital audio processor. The pickup mechanism adopts the latest version mechanism made by Philips. This mechanism is isolated by a solid 3 mm thick steel sub-chassis to shut off vibration and other disturbance factors, and is combined with a servo decoding circuit unique to audio analog to reduce data errors and noise. The digital processor contains 24 bit precision resampling and re-locking circuits and a 96kHz/24bit D/A converter. In addition to the normal 44.1 kHz, you can listen to the sound upconverted to 96 kHz by selecting the mode. This function is also effective for external digital input. The signal of DVD, MD, PC, etc. can be converted to 96 kHz and output as digital. Equipped with loop mode function, the signal sent to an external digital processor can be converted back to Mestro CDP for analog conversion. The re-locking circuit reduces jitter by up to 30 dB. All stages of the analog circuit are differential amplifier circuits. The output jacks are equipped with balanced and unbalanced outputs. Wireless remote control is included. Type CD Player Total harmonic distortion factor 0.001% or Less (1 kHz, -10dB) Frequency characteristic 0 Hz to 48 kHz ± 0.1 dB Jitter reduction 0.00005% Noise floor -140dB Digital input impedance 75 Ω Output impedance 40 Ω, 110 Ω Channel separation 100 dB or more Analog output level 2Vrms Analog output stage Semiconductor with a matching differential FET input Digital output level 0.5Vp-p/75 Ω (S/Pdif standard) Digital input sensitivity 0.5Vp-p/75 Ω (S/Pdif standard) Digital processing 24-bit real-time resampling Data buffering, low-noise jitter, and relocking Analog filter Secondary Butterworth filter Nominal voltage 100 VAC, 50Hz/60Hz Maximum Power Consumption 100VA External dimensions Width 445x Height 135x Depth 360 mm Weight 20.0kg Attachment Wireless Remote Contro Odpisz, cytując Link do komentarza Udostępnij na innych stronach More sharing options...
fader_audio Napisano 8 lutego Udostępnij Napisano 8 lutego Witam, Czy ogłoszenie jest jeszcze aktualne?? czy cena podlega negocjacji?? Zjakiego rejonu Polski Pan jest??? pozdrawiam Michał Odpisz, cytując Link do komentarza Udostępnij na innych stronach More sharing options...
