rodzynkiwczekoladzie Napisano 6 lipca 2010 Napisano 6 lipca 2010 Witam!Bardzo prosiłbym o wyjaśnienie co znaczy log w EAC. Dokładniej chodzi mi o "Selected bitrate 192 kBit/s".Znaczy to tyle że ktoś przerobił mp3 192 kbit/s na FLAC?Z góry dziękuje!Exact Audio Copy V0.99 prebeta 4 from 23. January 2008EAC extraction logfile from 4. December 2009, 8:33Various / Best of Chill Out LoungeUsed drive : PIONEER DVD-RW DVR-112D Adapter: 1 ID: 0Read mode : SecureUtilize accurate stream : YesDefeat audio cache : YesMake use of C2 pointers : NoRead offset correction : 48Overread into Lead-In and Lead-Out : NoFill up missing offset samples with silence : YesDelete leading and trailing silent blocks : NoNull samples used in CRC calculations : YesUsed interface : Installed external ASPI interfaceUsed output format : User Defined EncoderSelected bitrate : 192 kBit/s Quality : LowAdd ID3 tag : YesCommand line compressor : C:\Program Files\E A C Audio\Flac\flac.exeAdditional command line options : -V -8 -T "artist=%a" -T "title=%t" -T "album=%g" -T "date=%y" -T "tracknumber=%n" -T "genre=%m" %sTOC of the extracted CD Track | Start | Length | Start sector | End sector --------------------------------------------------------- 1 | 0:00.00 | 5:57.66 | 0 | 26840 2 | 5:57.66 | 4:06.22 | 26841 | 45312 3 | 10:04.13 | 5:07.14 | 45313 | 68351 4 | 15:11.27 | 5:09.32 | 68352 | 91558 5 | 20:20.59 | 9:14.72 | 91559 | 133180 6 | 29:35.56 | 6:53.31 | 133181 | 164186 7 | 36:29.12 | 3:13.00 | 164187 | 178661 8 | 39:42.12 | 7:07.51 | 178662 | 210737 9 | 46:49.63 | 5:58.01 | 210738 | 237588 10 | 52:47.64 | 4:20.17 | 237589 | 257105Range status and errorsSelected range Filename G:\tvixhd1\lossless-room.moole.ru\_Various - Best of Chill Out Lounge\Various - Best of Chill Out Lounge.wav Peak level 97.7 % Range quality 99.9 % Test CRC CF641C45 Copy CRC CF641C45 Copy OKNo errors occurredAccurateRip summaryTrack 1 not present in databaseTrack 2 not present in databaseTrack 3 not present in databaseTrack 4 not present in databaseTrack 5 not present in databaseTrack 6 not present in databaseTrack 7 not present in databaseTrack 8 not present in databaseTrack 9 not present in databaseTrack 10 not present in databaseNone of the tracks are present in the AccurateRip databaseEnd of status report Odpisz, cytując
pacio94 Napisano 6 lipca 2010 Napisano 6 lipca 2010 Tu wogóle są trzy rozbieżne informacje:-po pierwsze masz podany bitrate 192kbps co sugeruje format wyjsciowy MP3, WMA czy inny podobny,-po drugie jako encoder jest "flac.exe",-po trzecie nazwa pliku jest z rozszerzeniem ".wav".Szczerze powiedziawszy nie wiem jak to wogóle możliwe, że taki log powstał, u mnie wyszstko zawsze jest czytelne. Skąd masz tego loga??? On jest twój, czy robił go ktos inny??? Odpisz, cytując
rodzynkiwczekoladzie Napisano 6 lipca 2010 Autor Napisano 6 lipca 2010 jest mój. to znaczy że mam coś nie tak z EACem? Odpisz, cytując
muzyczny_gość Napisano 6 lipca 2010 Napisano 6 lipca 2010 a nie jest to zwykły fake ? Odpisz, cytując
pacio94 Napisano 6 lipca 2010 Napisano 6 lipca 2010 Nie wiem, dlaczego ci się tak robi. Zamiast tego 192kbps powinien pokazywac wartosci próbkowania i ilosci bitów tak jak w przypadku WAVE i może jeszcze poziom kompresji (od 1 do 10), ale jesli wszystko ci działa to nie ma problemu, raczej nieprawdopodbne jest, żeby zanim encoder zrobi FLACa, tworzył dodatkowe MP3. Odpisz, cytując
rodzynkiwczekoladzie Napisano 6 lipca 2010 Autor Napisano 6 lipca 2010 zadałem to samo pytanie na innym forum i odpowiedziano mi tak: Cytat Zapewne nie. To jest prawdopodobnie "bug" w eac'u. Ktos pewnie zaznaczyl 192 bitrate, a i tak wybral kodowanie do flaca. Odpisz, cytując
pacio94 Napisano 7 lipca 2010 Napisano 7 lipca 2010 Nie wiem jak przeglądam opcje EAC to nie widzę, żeby była możliwosć zrobienia czegos takiego. Chyba, że to jest zjawisko na zasadzie, że najpierw masz wybrane MP3 192kbps, a później jak wybierzesz FLACa to EAC jakby pamiętając poprzednią opcję do loga wpisuje ten bitrate. W końcu to free software, ktos to pisał, a rozwój tego nie dotarł nawet do oficjalnej wersji 1.0 Odpisz, cytując
muzyczny_gość Napisano 7 lipca 2010 Napisano 7 lipca 2010 a nie jest to mp3 skonwertowane do FLAC? Odpisz, cytując
pacio94 Napisano 7 lipca 2010 Napisano 7 lipca 2010 Ja bym wykluczył tę opcję, bo do tego potrzebny jest inny encoder, którego nie ma EAC w standardzie, a to zgrywanie (ripowanie), więc nie pliki MP3, a płyta CD Audio. Odpisz, cytując
