iosman123 Napisano 13 sierpnia 2019 Napisano 13 sierpnia 2019 Hi, At the outset I would like to point out that I am a beginner when it comes to turntables and my knowledge of them is quite poor. The problem is that when I start the turntable, move the arm, the disc starts spinning, but when I release the arm (over the record), the turntable stops working. Do you know what this can be due to? I will point out that the turntable does not have a head installed temporarily. I also do not know what happened with this equipment before, because I dug it out at a friend's in the attic, and she also did not know in what condition it was. thanks iosman Odpisz, cytując
iosman123 Napisano 28 sierpnia 2019 Autor Napisano 28 sierpnia 2019 Dnia 8/13/2019 o 7:19 PM, iosman123 napisał: hi, At the outset I would like to point out that I am a beginner when it comes to turntables and my knowledge of them is quite poor. The problem is that when I start the turntable, move the arm, the disc starts spinning, but when I release the arm (over the record), the turntable stops working. Do you know what this can be due to? I will point out that the turntable does not have a head installed temporarily. I also do not know what happened with this equipment before, because I dug it out at a friend's in the attic, and she also did not know in what condition it was. thanks... iosman thanks my issue has been fixed. Odpisz, cytując
