Gość Napisano 18 lipca 2022 Napisano 18 lipca 2022 (edytowany) SABAJ A30a Power Amplifier 200W*2 499 USD https://hifi-express.com/products/sabaj-a30a-power-amplifier Using the latest DSP chip with ST high-power amplifier chip, carefully designed and debugged, its distortion is as low as 0.0008%; The second generation XMOS solution, PCM sampling rate up to 32bit/768kHz; Subwoofer pre-output used to connect an active subwoofer to form a 2.1 audio system; Built-in multiple EQ modes and high/bass adjustment functions to easily match various speakers and music; The Bluetooth solution supports encoding formats such as LDAC/aptX-HD/AAC/SBC! All aluminum alloy CNC processing technology, using anodizing technology, fine workmanship, first-class touch; The color display screen and user-friendly operating system are easy to understand, equipped with full-function remote control function; A large number of audiophile-grade audio components are used to enhance the subjective sense of hearing; High-quality gold-plated input and output terminals; Perfect overheating, overcurrent, and other protection circuits; A high-quality power supply dedicated to audio. Inputs ...........................................USB / Optical / Bluetooth /Coaxial / LINE IN THD+N ................................................................................................0.0008% SNR ..........................................................................................................116dB Channel separation ...................................................................................108dB Output power...........................................................200Wx2(4Ω) / 100Wx2(8Ω) Subwoofer output level..............................................................................2Vrms USB transmission ....................................................................Asynchronization USB compatibility ..................................Windows 7 / 8 / 8.1 / 11(Needs Driver) Mac OSX、Linux(Driverless) Bit depth ......................USB 1bit, 16 ~ 32bit Optical / Coaxial 1bit, 16 ~ 24bit Sampling rate ...............USB PCM 44.1 ~ 768kHz DSD 2.8224-22.5792MHz Optical / Coaxial PCM 44.1 ~ 192kHz Bluetooth specification...................................................................................5.0 LDAC ..................................................24bit/96kHz (990kbps/660kbps/330kbps) aptX-HD ..........................................................................24bit/48 kHz_576kbps aptX .............................................................................16bit/44.1 kHz_352kbps SBC ..............................................................................16bit/44.1 kHz_328kbps AAC ..............................................................................16bit/44.1 kHz_320kbps Standby power consumption.........................................................................<0.5W Size ...........................................................................280x63x260mm (WxHxD) Weight ..........................................................................................3.3kg/7.28lbs Edytowano 18 lipca 2022 przez Tomasz S. Odpisz, cytując
lysy Napisano 19 lipca 2022 Autor Napisano 19 lipca 2022 OCTAVIO AMP ( 3300 PLN ) Specyfikacja techniczna: Wejścia analogowe: 2 x RCA Wyjścia analogowe: 1 x sub-out (RCA) Wejścia cyfrowe: 1 x optyczne, USB-A Łączność: LAN, Wi-Fi, Bluetooth 5.0 Moc wyjściowa: 2 x 35 W/8 Ω, 2 x 65 W/4 Ω Efektywność: >92% Całkowite zniekształcenie harmoniczne (THD): <0,005% Odtwarzane formaty: FLAC, OGG, ALAC, WMA, APE, MP3 Konwerter D/A: Burr-Brown PCM1798 Pobór mocy w trybie czuwania: <0,5 W Wymiary (W/S/G): 3,9/19,6/19,6 cm Odpisz, cytując
Alighieri Napisano 22 lipca 2022 Napisano 22 lipca 2022 (edytowany) Po pierwsze @lysyrafal, dzieki za swietny topic, od lat jestem fanem i uzytkowniekiem. Dnia 18.07.2022 o 09:49, Tomasz S. napisał: SABAJ A30a Power Amplifier 200W*2 499 USD https://hifi-express.com/products/sabaj-a30a-power-amplifier To wyglada naprawde ciekawie, nareszcie cos nowego, w sensie ideowym na ksztalt SMSL VMV A2, ale bez koszmarnie absurdalnej ceny. Tu chyba najciekawsza dyskusja. Edytowano 22 lipca 2022 przez Alighieri Odpisz, cytując
lysy Napisano 10 sierpnia 2022 Autor Napisano 10 sierpnia 2022 WAVERSA SYSTEMS WSLIM-LITE ( 7800 PLN ) Specyfikacja: 1. Wyjściowe wyjście głośnikowe (kompatybilne z wtykami bananowymi) 2. Wejście A.Ethernet: DLNA, Roon Ready, WNDR B.USB-B: PCM 24 bity / 384 kHz C.USB-A: funkcja rozszerzona D.Koncentryczny: 192 kHz E.Optyczny: 96 kHz F.Tuner FM: 88 ~ 108 MHz 3. Wzmacniacz o mocy 80 W/ kanał, (8 PPBTL na kanał (łącznie 16)) 4. Wyświetlacz wyświetlacz IPS, nowy interfejs użytkownika Waversa Systems 5. Zasilacz DC24V 6. Wymiary D300 x G190 x W20 mm 1 Odpisz, cytując
szyt Napisano 15 września 2022 Napisano 15 września 2022 BlueSound wydaje nowego, mniejszego PowerNode'a: 40 Watts per channel of DirectDigital™ amplification technology handling 24 bit/192 kHz files A state-of-the-art Quad-Core 1.8GHz ARM® Cortex A53 Processor HDMI eARC connectivity Digital optical and analog input options, subwoofer output, and Bluetooth® wireless headphone output Dolby® Digital decoding Dual-band Wi-Fi, Gigabit Ethernet and support for 2-way Bluetooth® aptX™ HD Stream hi-res content from internet radio stations, cloud music services or your own local music players Intuitive control with the BluOS Controller app Elegant capacitive touch panel for quick-access controls (Play, Pause, Volume Up/Down, Previous/Next Track) Includes an easy-to-install, multi-orientation wall-mounting bracket IR remote learning capability – optional control using the RC1 Remote Controller Connect with the BluVoice skill to enable voice assistants like Alexa, Google Assistant and Siri to control Players around the home. AirPlay 2 lets you play music or podcasts from wireless stereo components throughout your house — all in sync. + Review: O ile design mi sie w klasycznym powernodzie bardziej podoba, tak fajnie, ze schodza z cena w dol, nie ścinając za bardzo ficzerow. Odpisz, cytując
lysy Napisano 27 września 2022 Autor Napisano 27 września 2022 BOOMBOOM 460 ( cena 470 PLN ) Specyfikacja techniczna: Obsługiwane profile Bluetooth: A2DP Wersja Bluetooth: 3.0, EDR, klasa 2 Obsługiwany kodek: aptX, SBC Zasięg: do 10 m z nadajnikiem klasy 2, do 30 m z nadajnikiem klasy 1 Opóźnienie dźwięku; aptX 60-80 ms; SBC 170-270 ms Pamięć parowania: do 8 urządzeń Pasmo przenoszenia: 10 Hz-22 kHz (+/- 3 dB) Impedancja głośników: 8Ω Wejście audio: jack 3,5 mm Wyjście audio: wyjścia głośnikowe Moc: 2 x 20W RMS Wymiary (wys. x szer. x gł.): 45 x 133 x 88 mm Waga: 275 g Zasilanie: 100-240 V AC 50/60 Hz, zasilacz micro USB 5 V DC (w zestawie) lub kabel micro USB (w zestawie) Pobór prądu w stanie spoczynku: <2 W Odpisz, cytując
lysy Napisano 10 października 2022 Autor Napisano 10 października 2022 (edytowany) Dnia 15.09.2022 o 10:49, szyt napisał: O ile design mi sie w klasycznym powernodzie bardziej podoba, tak fajnie, ze schodza z cena w dol, nie ścinając za bardzo ficzerow. W przypadku funkcjonalności tak, ale jednak coś traci w porównaniu do większego brata. Traci na mocy, która wynosi 40 W na kanał, a jego większy brat ma 80 W Edytowano 10 października 2022 przez lysyrafal Odpisz, cytując
lysy Napisano 22 grudnia 2022 Autor Napisano 22 grudnia 2022 NuPrime OMNIA A200 ( cena 5800 PLN ) Specyfikacja techniczna: Power: 150W @ 8 ohms; 250W @ 4 ohms (both channels driven) THD: <0.09% (AUX IN, 1W, @ 8 & 4 ohms) <0.06% (OPT IN, 1W, @ 8 & 4 ohms) Signal-to-Noise Ratio: >90 dB (Digital input, 10W out @ 8 ohms) Clipping power: >290W (1kHz @ 4 ohms, both channels driven) Frequency Response: +0.6 dB/-idB (12Hz – 22kHz) Channel Separation: >85 dB (1kHz AUX): >105 dB (10kHz Digital) Input Sensitivity: 0.95V (AUX & OPT) for 100W @ 8 ohms 0.85V (AUX & OPT) for 100W @ 4 ohms DAC & Wireless Bit Depths: 16/24 bit Optical S/PDIF Input: PCM up to 192kHz Coaxial digital output Analog Line Out Streaming Technologies: Bluetooth 5.0 (aptX HD), DLNA, AirPlay Network Connectivity: Gigabit Ethernet RJ45, 802.11 b/g/n Wi-Fi Streaming Services: Deezer, iHeartRadio, Qobuz, QQ Music, Spotify, TIDAL, TuneIn Product Weight: 3kg Product Dimensions (W x H x D): 280 x 55 x 250 mm (includes feet and extended rear panel terminals) Package Dimensions (W x H x D): 440 x 100 x 340 mm Shipping Weight: 4.5kg Odpisz, cytując
lysy Napisano 22 grudnia 2022 Autor Napisano 22 grudnia 2022 NuPrime STA-9X ( cena 6400 PLN ) Specyfikacja techniczna: Wejścia: RCA: wejście niezbalansowane x 1 XLR: Wejście zbalansowane x 1 Trigger IN (12V) Wyjścia: Wyjście głośnika stereo x 1 Wyjście głośnika mono x 1 Trigger OUT (12V) Moc: 2 x 130 W / 1 x 330 W przy 8 omach Szczytowa moc wyjściowa: 2 x 170 W / 1 x 370 W przy 8 omach Impedancja wejściowa: 47 k Ohm Stosunek sygnału do szumu: > 90dB przy 1W, 10W, 100W THD+N: 0,005% (stereo) / 0,005% (mono) Pasmo przenoszenia: 10Hz do 50kHz Napięcie AC na całym świecie: (115 VAC / 230 VAC) z przełącznikiem wyboru napięcia na spodzie urządzenia Bezpiecznik AC: 3A, 250VAC Wymiary: 235 mm szer. x 281 mm głęb. x 60 mm wys. (wraz z nóżkami) Waga: 4 kg Kolor: czarny lub srebrny Odpisz, cytując
Piotr Sonido Napisano 23 grudnia 2022 Napisano 23 grudnia 2022 Cy ten jest jescze kompaktowy? Cabasse Abyss Moc: • 2 x 215 W/4 Ω • 2 x 120 W/8 Ω Łącza: Ethernet, Wi-Fi, Bluetooth, optyczne S/PDIF, analogowe RCA, USB, mini-jack TV, wyjście dla słuchawek, wyjście dla subwoofera Obsługiwane formaty audio: MP3, AAC, WMA, AIFF, FLAC, ALAC, Ogg, Vorbis, DSD 64/128, WMA • DFE: Dynamic Fidelity Enhancer • DEAP : Digital Enhancement of Acoustical Performances • System multiroom high-resolution Wymiary: 245 x 97 x 221 mm Waga: 3,5 kg Cena detaliczna: 8 190,00 zł brutto Odpisz, cytując
lysy Napisano 23 grudnia 2022 Autor Napisano 23 grudnia 2022 Jasne że jest kompaktowy, przynajmniej tak założyłem na początku tego tematu, a mianowicie: -szerokość do 30 cm -głębokość do 30 cm -wysokość do 10 cm Odpisz, cytując
Gość Napisano 17 stycznia 2023 Napisano 17 stycznia 2023 Takie małe pudełko z HDMI ARC za 149 euro https://www.audiophonics.fr/en/integrated-amplifier/arylic-b50-amplifier-two-way-bluetooth-52-aptx-hd-hdmi-arc-2x50w-4-p-17257.html Specifications Product typeAmplifier Amplification typeClass D InputsBluetooth 5.2 1* USB-C 1* USB-A (USB Host) 1* Optical Toslink 1* Stereo RCA line input 1* Stereo RCA Phono input (MM/MC) 1* HDMI ARC OutputsBluetooth 5.2 Speaker terminals 1* RCA subwoofer output Bluetooth version5.2 Supported Bluetooth codecsSBC, AAC, aptX, aptX HD Output power2*50W @ 4Ω, 24V 2*30W @ 8Ω, 24V Frequency response20Hz - 20kHz THD+N< 0.1% @ 1W, 1kHz SNR> 93dB Line input level2Vrms Subwoofer output level3Vrms Subwoofer output cutoff frequency250Hz General Supply voltage24V 4.16A (Included) Dimensions (L*P*H)185*155*50mm Weight900g ColorBlack Odpisz, cytując
lysy Napisano 23 stycznia 2023 Autor Napisano 23 stycznia 2023 Lindemann Musicbook Power II 1000 ( cena 18000 PLN ) Specyfikacja techniczna: Wejścia XLR: symetryczne analogowe wejścia liniowe Napięcie wejściowe dla pełnej skali: 2,38 V Impedancja wejściowa: 20 kΩ Wyjścia głośnikowe: Bezpieczna wtyczka laboratoryjna 4 mm Zakres impedancji głośników: nominalnie 4-8 omów Moc wyjściowa: 2 x 500 W przy 4 omach Wzmocnienie: 26 dB THD: <0,003% Pasmo przenoszenia: 1 Hz - 50 kHz (-3 dB) Stosunek sygnału do szumu: 110 dB Ogólnie Zasilanie sieciowe : 90-240 V, 50-60 Hz Pobór prądu: 0,5 W w trybie czuwania, 26 W podczas pracy, 1200 W maksymalnie Wymiary: 280 x 220 x 63 mm (szer. x gł. x wys.) Waga: 3,4 kg Automatyczne włączanie Próg włączenia: ok. 0,2 mV symetrycznie (sygnał w lewym kanale) Opóźnienie włączenia: ok. 2-3 sekundy Czas wyłączenia: po upływie ok. 60 minut Odpisz, cytując
Szymek3392 Napisano 21 lutego 2023 Napisano 21 lutego 2023 (edytowany) AUDIOPHONICS DAW-S250NC (Cena 921,5 Euro z podatkiem) Class D Integrated Amplifier NCore DAC ES9038Q2M WiFi Bluetooth 5.0 2x250W 4 Ohm 32bit 768kHz DSD256 The real engine of this DAW-S250NC, the Hypex NCore NC252MP Class D amplifier moduledelivers considerable power, up to 2x250W under 4Ω, with great efficiency and ease, while maintaining a compact size. Its main characteristic reveals itself in its great linearity and its ability to ensure a very low level of distortion. The DAW-S250NC reveals a sound reproduction as transparent as detailed to present you your music as close as possible to its recording in studio. Technical characteristics SPECIFICATIONS Product typeIntegrated amplifier InputsBluetooth 5.0 WiFi 1x USB-B 1x Coaxial 1x Optical Toslink OutputsSpeaker terminals 1x Stereo RCA Pre-Out AmplifierHypex NCore NC252MP DACESS ES9038Q2M USB InterfaceXMOS XU208 Output power2x 250W @ 4Ω 2x 150W @ 8Ω Supported sampling ratesUSB : PCM up to 32bit 768kHz, DSD DoP up to DSD256 Coaxial / Optical : PCM up to 24bit 192kHz, DSD DoP up to DSD64 THD+N0.0015% SNR121dB OLED ScreenBrightness not adjustable, but switches off after 40 seconds Supported WiFi protocolsDLNA / UPnP AirPlay 2 Spotify Connect Supported streaming services (via WiiM Home app)Spotify Deezer Tidal Qobuz Amazon Music Napster Pandora QQMusic Supported webradios (via WiiM Home app)TuneIn iHeartRadio RadioParadise vTuner GENERAL Power supply110-230V AC ColorGray Dimensions300*295*60mm Weight~ 2.45kg Package1x Audiophonics DAW-S250NC 1x Remote control (batteries included) 1x Power cable 1x Bluetooth / WiFi antenna Edytowano 21 lutego 2023 przez Szymek3392 Odpisz, cytując
lysy Napisano 10 kwietnia 2023 Autor Napisano 10 kwietnia 2023 (edytowany) Pro-Ject Maia DS3 Specyfikacja techniczna: Moc wyjściowa:2x 80 W/140 W przy 8 omach/4 omach (1% THD) Pasmo przenoszenia (20 Hz - 20 kHz):<+/- 0,3 dB przy 20 kHz SNR:97 dB (105 dB - ważony „A”) przy 1 kHz THD:< 0,01% przy 10 W / 8 omów Wyjście wzmacniacza słuchawkowego:2x 430 mW przy 32 omach (1% THD) Wejścia liniowe:3 pary RCA (czułość: 860 mV) Wejście gramofonowe:1 para RCA (dla wkładek MM, MI i MC) Czułość wejścia gramofonowego:MM 47 k omów / MC 100 omów Wzmocnienie wejścia gramofonowego:MM 40dB / MC 60dB Wejście USB:USB Audio Class 2 (wymaga USB 2.0 lub nowszego) Częstotliwości próbkowania PCM:do 192 kHz / 24 bity Obsługa DSD:DSD64, DSD128, DSD256 Wersja i kodek BT:BT 5.0; aptX, aptX HD, profil A2DP Wyzwalanie wejścia/wyjścia:Detektor włączania/wyłączania 12 V Zasilanie zewnętrzne:36V/5,5A prądu stałego Zużycie energii w trybie czuwania:< 0,5 wata Wymiary szer. x wys. x gł.:206 x 71 x 240 (252 z gniazdami) mm Waga:1850g bez zasilacza Edytowano 10 kwietnia 2023 przez lysy Odpisz, cytując
lysy Napisano 10 kwietnia 2023 Autor Napisano 10 kwietnia 2023 SVS Prime Wireless Pro Soundbase ( posiada HDMI ) Specyfikacja techniczna: Wzmacniacz wzmacniacz sieciowy Pasmo przenoszenia 10Hz - 20kHz (±1 dB) Moc wyjściowa 2 x 150W (RMS) Sieć Wi-Fi (2,4 oraz 5 Ghz) Wspierane formaty aptX, AAC Streaming - internetowe serwisy muzyczne, - radio internetowe, - Spotify Connect, - Apple Airplay 2 dla iPhone'a i urządzeń z iOS, - Chromecast dla urządzeń z system Android, - DTS Play-Fi w jakości 192kHz/24-bit Bluetooth (v 5.0) Wejścia cyfrowe Optyczne toslink, HDMI (ARC, eARC) Wejścia analogowe Line In (RCA oraz mini jack 3,5mm) Wyjścia audio RCA, SUB out, wyjście słuchawkowe, terminale głośnikowe Akcesoria w zestawie Pilot, baterie, kabel zasilający, instrukcja obsługi Waga 2,30 kg. Wymiary 82.0mm (H) X 230.8mm (W) X 223.8mm (D) Odpisz, cytując
lysy Napisano 10 kwietnia 2023 Autor Napisano 10 kwietnia 2023 Postanowiłem cen wzmacniaczy nie zamieszczać, ponieważ mogą się one bardzo różnić i wprowadzają w błąd czasami. Jest nazwa sprzętu, specyfikacja techniczna oraz zdjęcia przód oraz tył, a cenę można samemu znaleźć, wynegocjować! Odpisz, cytując
Chyba Miro 84 Napisano 10 kwietnia 2023 Napisano 10 kwietnia 2023 Myślę ze podawanie cen fajna sprawa. Można zobaczyć jak ewoluuje cena na przestrzeni pewnego okresu. Odpisz, cytując
szyt Napisano 11 kwietnia 2023 Napisano 11 kwietnia 2023 Widze dodali HDMI i AirPlay wzgledem poprzedniej wersji, fajnie fajnie, to powinien byc standard w takich urzadzeniach. Natomiast design tych wzmakow SVS tak srednio do mnie przemawia. Odpisz, cytując
lysy Napisano 11 kwietnia 2023 Autor Napisano 11 kwietnia 2023 @Chyba Miro 84 Szczególnie mając uwadze, kiedy ten temat powstał tzn. okres pandemiczny i później nagły wzrost cen poprzez braki sprzętu ( o ile jest jeszcze dostępny ) lub dlatego, że wszyscy tak robili. Mnie bardziej chodzi o ceny w czasie rzeczywistym, gdyż nie zawsze uda mi się znaleźć tę najniższą, a taka byłaby najbardziej pożądana. 1 Odpisz, cytując
lysy Napisano 5 maja 2023 Autor Napisano 5 maja 2023 NuPrime IA-9X Specyfikacja techniczna: Moc ciągła (RMS): 90W@8Ohm, 145W@4Ohm Typ: Tranzystorowy Klasa: D Kontrola tonów: NIE SEKCJA AUDIO: Wbudowany DAC: NIE Przedwzmacniacz gramofonowy: TAK MM Stosunek sygnał/szum: @5W 95dB, @50W 105dB Zniekształcenia THD: 0.0014% Pasmo przenoszenia: 10 - 50.000Hz Pojemność wejściowa MM: 100 pF / 220 pF / 320 pF Napięcie wejściowe MM: 4.0 mV @ 1KHz Wzmocnienie MM: Wejście MM do wyjścia LINE (głośność/maks.) => 65 dB przy 1 KHz Impedancja wejściowa: 47K Ohms Rezystancja: MM: 32K ohm / 47K ohm / 100K ohm FUNKCJONALNOŚĆ MULTIMEDIALNA: Wi-Fi: NIE UPnP: NIE AirPlay: NIE Wejście USB Apple iPhone/iPod: NIE WEJŚCIA/WYJŚCIA: Wejścia 2 x RCA liniowe: 2 Wejścia 2 x XLR: 1 Trigger: TAK 2 Wyjście subwooferowe: NIE Wyjścia głośnikowe: 1 komplet Wejścia gramofonowe 2 x RCA: 1 INNE: Korekcja RIAA 1x trigger wejściowy, 1x trigger wyjściowy (DC12V 3-pin 3.5mm mini jack) Pilot: TAK Zasilacz: Napięcie AC na całym świecie: (115 V AC / 230 V AC) z przełącznikiem wyboru napięcia Zużycie prądu: Czuwanie: 3.3W @ 230V, spoczynek: 11.5W @ 230V Wysokość: 6cm Szerokość: 23.5cm Głębokość: 28.1cm Waga: 3.8kg 1 Odpisz, cytując
Gość Napisano 13 czerwca 2023 Napisano 13 czerwca 2023 Myślę ,że całkiem fajna opcja, obecnie w niższej cenie 217 euro https://hifi-express.com/products/smsl-al200?variant=44007425147124 Odpisz, cytując
Józef Herczek Napisano 13 czerwca 2023 Napisano 13 czerwca 2023 W tych pieniądzach na papierze wygląda świetnie i ta mnogość wejść 👍 Odpisz, cytując
Jakebut Napisano 13 czerwca 2023 Napisano 13 czerwca 2023 Wygląda intrygująco. Szukam czegoś tańszego do zestawu na biurko, dotychczas faworytem był Topping MX5, ale już cenowo nie wypada tak dobrze jak kiedyś 😩 Odpisz, cytując
Artur Charicki Napisano 13 czerwca 2023 Napisano 13 czerwca 2023 Myślę że to ulepszony A300 + DAC. Odpisz, cytując
